Mike Ward
- Dec 8, 2001
here is a brand new in the box panamax 5100
Panamax Max5100
Four AC outlets are fed through a "double L” filtration circuit to eliminate EMI/RFI noise on all three power paths (L-N,L-G&N-G) so even equipment with 2-blade plugs receive clean uncontaminated power. These can be set as either always-on or switched with delayed turn-off. Four more always-on outlets utilize a separate “double L” filtration circuit to provide power for audio/video components requiring constant power. Two delayed-on outlets for high-current components such as amplifiers and powered sub-woofers, provide clean, filtered power without limiting the current available to the connected equipment. SurgeGate Plus™ Circuitry A Power monitoring system that acts as a gate to prevent unsafe voltages from damaging sensitive electronic equipment. It automatically detects a prolonged over or undervoltage condition and disconnects the power to equipment, then reconnects it when the power returns to a safe level. automatically detects a prolonged over or undervoltage condition and disconnects the power to equipment, then reconnects it when the SignalPerfect™ Technology For 2 coaxial (1 satellite TV & 1 off-air/cable TV) lines and 1 pay-per-view telephone line provides optimized, application specific protection against signal line surges. Protect or Disconnect™ Technology Protection circuitry for catastrophic surges. Convenience Features DC Voltage trigger input and pass-through output for initiating a start-up/shut-down sequence. LED Voltmeter indicates line voltage.
WARRANTIES $5,000,000 Connected Equipment Protection Policy Panamax will protect your equipment or we will repair or replace up to $5,000,000! 3 Year Product Warranty The surge protector shall be free of any defects in design, materials, or workmanship, and Panamax will repair or replace any defective product up to three years from the purchase date.
$300 shipped or best offer
Panamax Max5100
