Panamax 1000+ w/ SVS & Denon 3801
Discussion in 'Archived Threads 2001-2004' started by Daniel Whelan, Aug 15, 2001.
  1. Daniel Whelan
    Mar 18, 1999
    23
    I know this has been mentioned on the forum before, but I couldn't really find a definite answer. I'm looking into using the Panamax 1000+ or the Panamax 500. The main difference is that the 1000+ allows you to have switched components triggered by the preamp and such.
    Would I be able to plug my Samson amp for my SVS subwoofer into the Panamax without adversely affecting performance? Would I need to use it in an unswitched outlet, or would it be ok in the switched or delayed outlets?
    Daniel
  2. derek
    derek Second Unit
    Dec 20, 1998
    494
  3. DaleB
    DaleB Stunt Coordinator
    Jul 23, 2000
    103
    I wrote Panamax one time asking a similar question. They told me the total unit is capable of handling 1800W, so they projected the use of most amplifiers will be easily supported.
