Painting Wegas
Discussion in 'Archived Threads 2001-2004' started by brian cr, Nov 19, 2001.
  1. brian cr
    brian cr Auditioning
    Nov 3, 2001
    13
    Has anyone attempted to paint a Sony Wega tv? What kind of paint/ application would you use? Would the warranty be voided? Black is the color I'm thinking of, of course.
  2. Tom Sanderson
    Tom Sanderson Auditioning
    Nov 11, 2001
    14
    First of all, let me ask the obvious question: why???
    Next, yes of course painting the TV will void it's warranty... if you can locate your Owner's Manual, and maybe read it, it will spell out exactly what you can and can't do... mostly can't. If you have no owner's manual, it means you're not the original owner, and the TV is most likely a few years old... in which case, the warranty period is most likely expired. It's up to you... I painted a TV with spray paint once by detaching all the plastic casings and painting them and letting them dry COMPLETELY before re-attaching... it worked.
  3. jeff peterson
    jeff peterson Supporting Actor
    Nov 29, 1998
    675
    I think you'd be better off just turning down your brightness instead of painting your TV screen black.
    [​IMG]
