Luke_Y
- Aug 20, 2001
Looking for some advice on painting the grills and frames on my Triad In-Wall Silver 4 Surround Speakers.
Let me elaborate on my situation- They are installed. Although beautiful, Triad grills are quite delicate (so much so that Triad wont accept returns). In my last house I had a set installed and tried to remove the grills later for painting, resulting in the grills creasing and having to order new ones (they are not cheap so I would like to avoid that this time). The speakers I have now are hand me downs from my brother. When he took them out of his wall he was extremely careful and still bent/creased the grills. I luckily got them for the cost of new grills
So... Have I told you how delicate the grills are and how much I don't want to remove them
Any opinions on how they would turn out if I painted them installed? The frame is no problem but I am worried about the grill. If i used a fairly dry brush do you think it would work out OK? How about a sponge brush?
Looking forward to some input.
