Painting Speaker Covers
Discussion in 'Home Theater Projects' started by Robert Shaw, Aug 14, 2004.
  1. Robert Shaw
    Robert Shaw Auditioning
    Jul 18, 2004
    2
    I have in-wall speakers and would like to paint the covers. Is this okay to do and do you have any tips? They are metal and white. Also, there is some material on the back of them.
    Any suggestions?
  2. Will d s
    Will d s Stunt Coordinator
    Jun 21, 2004
    75
    If you just paint the metal part you will not affect the acoustics. Just make sure you do not fill in the holes with paint.
  3. Rutgar
    Rutgar Second Unit
    Jan 17, 2004
    495
    As Will said, you can get away with painting the metal parts. But absolutely, under no condition should you paint the grill cloths. "Guilford of Main" sells an array of "acoustically transparent" materials in assorted fabrics, and colors. It can be bought here:
    http://www.silentsource.com/acoustic...lorchart3.html
    If you want just plain "Black" speaker grill cloth, it can be purchased here:
    http://www.partsexpress.com
