JamieD
- Apr 5, 2002
Hey folks. Not necessarily DIY speaker related, more DIY in general related. How do you get your smooth (no brush mark) finishes? I've been using some oil paints on some projects, and I sand down to a flat layer, but then when I put the next coat on to "level" the color, the marks are back! Should I spray, sponge, roll, brush, thin the paint, or wha? Thanks!!
