PA amp system integration help
Discussion in 'AV Receivers' started by joe_di, Mar 22, 2004.
  1. joe_di
    joe_di Auditioning
    Dec 9, 2003
    9
    Is there anyway I can use a PA amp that has XLR connections in conjunction with my harmon kardon avr 7200? Let's say I want to use the PA amp as a power ampifier to drive my front two channels and use the avr7200 as a preamp. How would I be able to do this?
    thxx
  2. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    Joe,
    If you were to, you'd need to adapt from the RCA pre-outs to the XLR connectors. Or, if the amp has phono-plug style inputs, you could adapt between the RCA and the phono plugs.
    With that being said, I'm not sure what you're looking for the amp to provide as the AVR-7200 is quite capable.
