Wayde_R
- Aug 25, 2003
I am currently struggling with the question, do I wait and save more money
to buy the Marantz 8200 which is just out of my budget. Or do I buy the
Pioneer Elite 43tx. Both are pretty close receivers and will meet my needs.
I use NHT ST-4 speakers for front and plan on picking up the sb3s for back
but for now I have some decent Missions that have served me well for years.
I use the matching NHT sc-1 for my centre channel.
I've listened to both at separate times (in different stores) I can't really tell any apparent difference in sounds, however you know how different showrooms are, they're not my living room. I don't know if I'd notice any difference between the two amps and I'd
rather just buy the Pioneer because it's cheaper and probably does all I need.
But then, that Marantz sr8200 is tugging at me, it's slightly heavier at five more lbs than the P-E, which appeals to the audiophile in me. Am I just being a slave to a brand? Or does spending the extra really
get me more?
Thanks for any opinions
Wayde
get me more?
Wayde
