Ryan DC
- Aug 7, 2002
First off I would like to wish everyone on this forum a merry christmas!
I have what seems to be a problem with my video 3 input connection on the front of this receiver. It only involves the video input (yellow) connection, the rest (back of receiver) work fine. What happens is whenever I connect my Ps2 using the video jack there are a bunch of vertical bars imposed on the screen with the graphics. Now whenever I connect using the s-video on the front or the other inputs on the back the picture is fine. I am using the monitor s-video out to my t.v.
This problem only seems to be associated with the Ps2 but my other video systems work fine through the front inputs (Snes,Ps1,genesis) although I haven't hooked up an Xbox to it yet. I was wondering what might be causing this problem? Whenever I pull out the video plug so that the outer ring doesn't touch the jack it goes away. I was also wondering if you could and had a Ps2, hook it up to your 4es through the video 3 composite inputs and report here whether you have this problem or not? That way we could see if this might be a design flaw of the 4es.
I appreciate your input on this and wish you all happy holidays!
