Kaskade1309
- Apr 7, 2020
- S
I finally bit the bullet and replaced our Onkyo SR605 from circa 2007 (which was still going strong save for a dying HDMI out) with a new Denon AVR-X2800h based on budget and needs. But being so familiar with Onkyo products (I wanted another one, but their new receivers don't allow you to see the sound mode you're in while confirming the input you're on at the same time, which was a deal breaker for me...along with the fact that they dropped the incredibly useful IntelliVolume feature), this has been something of a learning curve ever since I set it up a week ago. What is confusing me more than anything is the way the Dolby Surround and DTS Neural:X upmixing systems deal with certain signals -- in my previous AVR, there was a menu that allowed you to assign every signal type to a specific codec. So Dolby Digital could be set to DD, DTS could set to DTS, two-channel content could be set to Pro Logic II, etc.
On these new AVRs, because Pro Logic II is no longer a thing, it seems that they memorize the last sound mode you use for each CODEC, and apply that the next time you view something -- this is becoming very daunting because I watch a ton of discs with different sound formats on them. If someone could help make some sense out of this, I would appreciate it.
The basics are these: we're running a standard 5.1 setup with Polk RTi towers in the front, a Polk CSi30 center, two SpeakerCraft in-ceiling speakers for surrounds (they were already installed in the house when we bought it) and a Polk PSW350 sub. I told the Denon we were running a 5.1 system when I first set it up, which is making this confusion with the "upmixers" even greater.
I spent a FULL WEEK playing with my new X2800, testing dozens of discs and attempting to understand how this thing works. Before I pack it up and send it back out of sheer frustration (and because I think my previous albeit old AVR just worked better for our needs), I have to go back to some fundamentals.
First of all, as I stated, I am running a basic 5.1 setup right now, and this seems to be confusing me with regard to how the Dolby Surround and DTS Neural:X upmixers are functioning (also based on their behavior when they see certain signals). Before I get to my questions I have about specific operational protocols when the OPTION menu on the remote is pressed, let me ask about some things that are truly making me a bit nuts (even after reading the online manual several times and taking in the audio mode assignment pages).
When I first set the 2800 up, I obviously told the software that we had only a left front, center, right front, left surround, right surround and subwoofer -- so it SHOULD know that we're running a 5.1 array. Now, I THINK I have figured out how the upmixers work in terms of memory, but I'm still confused about why certain modes are being activated for certain situations; to begin with, why is Dolby Surround or DTS Neural:X activating when we don't have any overhead speakers for an Atmos setup? Is it based on the LAST selection I made based on that codec?
What happened was this: I applied DTS Neural:X to a two-channel DTS-HD Master Audio soundtrack that was on a Blu-ray, and this sent the dialogue to the center where it belonged...but now EVERY time I watch a disc with Master Audio, even if it's 5.1/7.1, the Denon is reading "DTSHD + Neural:X" -- am I to assume this is because Neural:X was applied the last time I watched something in DTS-HD Master Audio, as was suggested earlier?
Here is my question, then: what are we actually HEARING if the Neural:X upmixer is being "applied" to a normal DTS-HD Master Audio signal played through our FIVE speakers? There are no additional speakers in which to "spread" the sound via the upmixer, so what are we hearing? Does this just indicate the upmixer was used last for this signal, but the processor isn't actually DOING anything to the incoming Master Audio signal?
In other words, when we watch discs with DTS-HD MA tracks, the receiver is showing "DTSHD + Neural:X," but I don't NEED the upmixer in the cases of plain 5.1 or 7.1 surround mixes -- is it actually "adding" anything to those tracks, or is it just a cosmetic notation on the display?
I suppose the same thing could be asked about Dolby signals -- if we're watching a disc with a standard Dolby Digital 5.1 surround track and the Denon applies Dolby Surround after that, is the signal being "enhanced" in any way being that we only have five speakers? I truly cannot grasp how these upmixers work and what they're doing.
Now, we're still getting (which is weird to me because, again, it's only a five speaker system) Dolby Atmos and DTS:X illuminating on the display when I watch discs with those soundtracks -- but is this because I kept the "Speaker Virtualization" setting on in the main setup menu? If so, what are we actually HEARING here, being that we don't have the overhead speakers? Are we basically getting the core Dolby TrueHD and DTS Master Audio signals but with some "reverb magic" applied by the AVR due to the Virtualizer setting? What's strange is that sometimes Dolby Atmos soundtracks play back as Dolby TrueHD ("DTHD" on the Denon display); it's almost like the AVR can't properly lock on to certain signals at times.
Was there something in the setup menu I missed to tell the auto sound modes to behave a certain way?
The primary question comes down to this: being that we only have five speakers, why are upmixers being engaged, even automatically? Just based on the fact that I used one for the last two-channel soundtrack I listened to? If that's the case, do I have to manually, each and every time, go in and switch the sound mode to straight DTS-HD to get the unaltered 5.1/7.1 mix?
With that out of the way, let me address some other questions that have been bothering me....
What does the TONE CONTROL selection do under the OPTIONS menu? It seems that there are only two choices, on or off, but what does this do? I thought it would open up bass and treble controls for at least the front channels, but I don't see any....are there actual tone controls available on these Denons?
What are the CHANNEL ADJUST settings under the OPTIONS menu, and what do they control? I see you can adjust each speaker from a "0 dB" point, but wasn't this already handled when I calibrated the AVR in the main setup menu? What do these levels control? Is it a temporary adjustment for the content you're currently watching, which then goes back to zero when the AVR is switched off?
Are there any options to turn off any kind of dynamic range compression, a late night mode, etc. while content is playing? Sometimes I feel like there's a "blanket" over the sound, which I didn't experience with my previous audio; I'm not running any EQ, but is there something that needs to be turned off while content is playing (like there used to be for Dolby content)?
Why do some choices pop up under OPTIONS when certain codecs are playing and not others? There seems to be a Dialog Enhancer, Tone, Level Adjust, Sync Level and something called All Zone Stereo....but these seem to vary based on the type of signal playing (unless I'm mistaken). Should these basically be left alone?
The correct setting in the subwoofer sub-menu is "LFE," correct -- not "LFE + Main"? I assumed this was like my previous AVR's "Double Bass" setting, wherein the front channels would get bass plus the sub if it was engaged, so I left it at "LFE" on the Denon.
What is the deal with the AUTO selection when you press the yellow button on the remote? When you press the PURE button, it opens up options for Pure, Direct and then Auto, and I was informed Auto was to be used so the AVR knows exactly what mode to go into when incoming signals are analyzed -- however, that doesn't seem to be happening when I press it. What seems to happen is the unit will go into a Pure or Direct mode even though I selected AUTO....does anyone know what is going on here?
