Jay H
Am I correct if I were run a 6v bulb at a higher voltage than it is designed for, it will be brighter but wont last as long?
I just built up a 5 D-cell battery pack to run a 6v 12Watt bike light. Used 5 cells because I want to run 1.2v NiMH D-cell batteries in series to make 6v. If I were to use brandy new Alkaline D-cells that would make it 7.5V. Although what I will actually do is simply run 4 and just jumper the 5th battery cell holder with a removable wire, I am currious about the electrical properties of overvoltaging a light bulb...
Jay
Jay
