ethan_l
- Oct 25, 2002
I've noticed that all the movies I've been playing on my 16:9 HDTV have a small part chopped off on the left and right side no matter what the aspect ratio the movie is in, when it projects onto the screen it gets cut
also since I'm running progressive scan, I can't change the aspect ratio on the TV because it's locked
just wondering if this is more a DVD issue
is there a fix for it or should I buy another player?
