Overlining text in word???
Discussion in 'Computers' started by Andrew S, Feb 28, 2005.
  1. Andrew S
    Andrew S Stunt Coordinator
    Sep 30, 2001
    214
    I can't for the life of me figure out how to place a line over a letter in wordperfect 12. I'm taking an electronics course and I'm trying to represent the compliment of a variable, and I want to overline it as opposed to the apostrphe in my lab reports, but I can't figure out how. Just something that's been bugging me for a while now, if anyone can point me in the right directin it would be much appreciated.
    Andrew
  2. Tekara
    Tekara Supporting Actor
    Jan 8, 2003
    783
    Well, I don't use wordperfect so I'm not going to be all that helpful. But I can at least give you some direction.
    The bar is called a macron. . . I'm not sure if that means much, but it might help you out when your looking through the help files.
    as an alternative, the standard unicode character set does have a few characters with the macron already, if that's of any use at all you can use the character map to copy them into your paper. It's in
    start -> programs -> accessories -> system tools
    when you bring it up, select the font that you are using in the top and then cycle through characters until you find one that's suitable.
    good luck!
