Outstanding Projector screen....for around $36.00
Discussion in 'Displays' started by DuWayne, Jan 13, 2004.
  1. DuWayne
    DuWayne Stunt Coordinator
    Sep 8, 2003
    160
    Ok, as some of you may know, I just recieved my Z2 and was projecting it on a textured wall with a glossy finished. This was by no means a perfect situation. Due to the wonderful picture I (thought) I was seeing, purchasing a $700 screen (or $260 material) just didn't seem worth it.
    So, this past weekend, a friend and I decided to build a screen that would not only do the job, but be WAY under the cost of traditional screens.
    So long story short (prob. too late):
    1. Went to Home Depot
    2. Purchased 2 8' MDF boards (2 1/2" wide)
    3. Purchased 2 4'x8' plywood boards with a flat-white vinyl coating
    4. Appropiate achors and screws
    I had Home Depot cut one of the 4'x8' boards to 1'x8'. This gave me my 5'x8' screen that I needed, while using the MDF as supports. The whole thing took about 45min to complete.
    The only thing now, is to get rid of the line where the two boards are joined. So I purchased some Scotch Plastic Tape. The only issue is, the tape is a little shiny, so I may get some White Masking Tape and see how that looks. That way I can always paint the Tape flat-white.
    image: 110'
    We put on "The Hulk" and was floored. But better yet, duing the day, we put on "Bad Boys II" and you wouldn't believe how much better the image look with ambient light still in the room.
    I promise, I will post pictures this week.
  2. Brajesh Upadhyay
    Brajesh Upadhyay Supporting Actor
    Jul 11, 1998
    787
    Interesting. Do you have a SKU/part # for the plywood board with flat-white vinyl coating? Why did you buy two pieces by the way? (Do they need to be stacked?)
    I'm a projector newbie--just got a Panny PTAE500U to replace my 53" HD RPTV. I got a white Gatorboard (as touted in an avsforum thread) from an art supply store & made that my screen. The results are great (not that I've compared it to a 'real' screen). I used (2" wide) industrial strength velcro to make the borders. The cloth side w/adhesive works great as a border.
  3. Thomas Willard
    Thomas Willard Stunt Coordinator
    Sep 15, 2003
    97
    It will be interesting to see if you can hide the seam. If not then a better approach might be to join the two panels of dry wall together, tape the joint, and then put a thin coat(s) of spackle on the entire surface to hide the seam. Then you can paint with either a flat white or something with a slight grey tint to increase contrast (if necessary). The cloth side of the adhesive backed Velcro sounds like a perfect border.
  4. kirtis_mcleskey
    kirtis_mcleskey Stunt Coordinator
    Dec 19, 2003
    87
    how much did it cost
    IM wanting a screen really bad , I mean wouldn it be better to have a 92 inch screen , than a 44 inch television that costs the same
  5. DuWayne
    Sep 8, 2003
    160
    ...hence the title of the thread.
  6. Brajesh Upadhyay
    Jul 11, 1998
    787
    I haven't tried it myself, but some avsforum guys have been happy w/the screen material from this eBay guy.
  7. DuWayne
    Sep 8, 2003
    160
    Ok...I put the White masking tape on top on the white Plastic tape and painted the masking tape with a Flat-White. Presto! The seam disappeared. When a picture is projected, it looks just like one 5'x8' piece of vinyl.
    This added $10.00 to the total cost.
  8. Mike Strassburg
    Mike Strassburg Second Unit
    Nov 4, 2001
    421
    Brajesh,
    Can't you provide any links to the discussions over on AVS about the E-bay screen material?? I've searched and searched and can't find any discussion of it. TIA...Mike
  9. Brajesh Upadhyay
    Jul 11, 1998
    787
  10. Todd Terwilliger
    Todd Terwilliger Screenwriter
    Feb 18, 2001
    1,745
    I ordered and received my material from the "ebay guy". I haven't had a chance yet to make a frame for the material but I tack it up just to see and it looked very good to my admittedly unedjucated eyes.
    I hope to put the screen together in a week or so. The material itself looks well made. I am not, however, very familiar with screen materials.
  11. Jack Shappa
    Jack Shappa Second Unit
    Jan 24, 2003
    411
    Sounds like the same thing I use, the doable products board (63036) from HD. Works as well or better than the Parkland Screen I used to have, and I didn't even need to paint it.
    - Jack
  12. Brajesh Upadhyay
    Jul 11, 1998
    787
    Hmm, I'll have to go to my Home Depot & see if they have it. They don't carry Parkland. I'm curious to see how it compares to my Gatorboard screen.
  13. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    This all brings back memories. Congratulations on your projector and screen. Will you be leaving it flat white?
  14. DuWayne
    Sep 8, 2003
    160
    I guess...I'm about to post pictures now...You tell me if I need to do anything else after you look at them.
  15. Aaron_*P
    Aaron_*P Stunt Coordinator
    Nov 22, 2003
    50
    I got screen material from ebay (user moakes i think). It works great, incredible picture.
  16. Eric Samonte
    Eric Samonte Screenwriter
    Mar 31, 1999
    1,318
    I wish I could get a 5" x 8" material and not have to put together 2 pieces. If u could get the seam to disappear, that would be just wonderful. I myself could probably muck it up and I have virtually 0 skill on mudding and taping.
    Right now, I'm using a 4 x 8 Misty Evening painted lauan plyboard, exiled to just adjusting the zoom on my pj when watching different ARs.
  17. Seth Paxton
    Seth Paxton Lead Actor
    Nov 5, 1998
    7,585
    I built my screen using some online advice a few years ago with 2"x2" boards as a frame, stretching a canvas paint drop-cloth over this frame, and then painting it first with a primer and then a recommend white paint (forget which type at the moment).
    It has made for a pretty effective and relatively lightweight screen with no lines, splotches, etc. I think the total cost was about $50 and all came from a Sherwin-Williams paint store.
  18. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    My projected image is pretty big (100" diagonal at 4:3) and i haven't been able to find a good way to create a one-peice screen. I dont really want to paint if i dont have to.
    Ill take a look at HD and check out your idea of the white plywood.
