outlook xp question
Discussion in 'Computers' started by Ted Lee, Mar 31, 2004.
  1. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    hi all -
    (version is outlook xp)
    according to my bud, everytime she hits the delete key in outlook, it *permanently* deletes the email --- it doesn't go to the "delted items" folder.
    she did say she this only happened after she tried to do a mass-deletion one day ... and it prompted her for something ...
    any ideas what's causing that? i did a quick google search, but didn't really come up with anything. i also bouned all over the options but couldn't find anything.
    thx!
    ted
  2. Gerald LaFrance
    Gerald LaFrance Supporting Actor
    May 28, 2002
    510
    Earth
    Gerald LaFrance
    did you check in tools, options, Maintenance there is an option to empty all messeges from the deleted items folder on exit, see if it is checked!!
  3. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    yeah, i did. it's not checked. plus, the email is deleted *as soon* as she hits the delete key. it never even makes it to the deleted items folder.
