Outlaw Audio Model 1050 vs. Denon AVR 2802
Discussion in 'AV Receivers' started by Mike Matthews, Aug 4, 2003.
  1. Mike Matthews
    Mike Matthews Stunt Coordinator
    Aug 1, 2003
    140
    which of these would you recommend, and why?
  2. RobWil
    RobWil Supporting Actor
    Mar 17, 2003
    733
    i'd recommend the Denon because you've already freakin' got it!
  3. ChrisHeflen
    ChrisHeflen Supporting Actor
    Sep 9, 2002
    912
    Mike, I watched the beating you took over on your other thread. Don't take it personal. I think there are more nice guys on here than the brow-beaters you got.
    Thanks for helping him out over there Rob you are crackin' me up! [​IMG]
    When you get the rest of your equipment, if you can afford it, I would purchase the Outlaw and try it in your home. Outlaw has a generous 30 day trial period. See which one works for best for YOU.
    FYI.. Outlaw is consistently recognized by most of the home theater magazines as a tremendous value, but the Denon is by no means a slouch either. I don't think you could go far wrong either way.
  4. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    Dont worry about the 2802. Its an excellent piece of equipment. Think about what you are going to pair it with and enjoy your new HT.
  5. RobWil
    Mar 17, 2003
    733
  6. ScottHH
    ScottHH Stunt Coordinator
    Oct 24, 2002
    174
    The 2802 has 6 amp channels, the 2803 has 7. I think these two models are more different than 'usual' in the Denon line.
    I don't think it's really worth much to switch from the Denon to the Outlaw or from the Outlaw to the Denon. (A used Outlaw 1050 can be had for a similar price.) But, that's not the question you asked.
    I have an older Denon that has served me very well. And I have my eyes on an Outlaw 950 down the road. I don't think you can go wrong with either of these units. The Denon 2802 has Dolby Pro Logic II, which the Outlaw 1050 is lacking. If this is important to you, it could sway your decision.
    You might also want to check out ubb.outlawaudio.com/ubb/Forum1/HTML/000715.html
    there's a thread discussing the 1050 vs. the Denon 2803.
  7. Mike Matthews
    Aug 1, 2003
    140
    the reason i ask is because i DON'T have the Denon. i got an email saying that there was a leak at the warehouse and several units got damaged, so i'm starting over at zero
    also, what exactly does Dolby Pro Logic II do??
  8. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    So you safely got out of that e-bay mess? Good for you, after taking all the flogging for that. DPL II is a newer enhanced DPL mode that has better ambiance (close to the the discreet 5.1 modes) unlike its older version that was focussed primarily on the center channel. If you have a lot of old VHS tapes and watch a lot of TV programming this is a good mode to be in.
  9. dan-0
    dan-0 Stunt Coordinator
    Aug 1, 2003
    156
    PLII
    As I understand it, PLII gives you multi-channel sound from a stereo source (ie. TV, CD, VHS...). Much like my current Denon (soon to be replaced) pro logic surround 5.1 receiver converts two-channel into 5 channel surround. PLII supposedly just does a better job of matrixing the sound then the 'ol surround sound or PLI.
    The outlaw does not have PLII, but I don't think that is a big issue unless you watch a lot of vhs or run your tv audio through your receiver. CD's you (or at least I do) would typically listen to in 2-channel anyway.
  10. Mike Matthews
    Aug 1, 2003
    140
    how do CDs sound when they come through all 5 speakers? i love the idea of listening to music through all speakers...
  11. RobWil
    Mar 17, 2003
    733
    I listen to 2-channel music strictly in 2-channel, and my current receiver doesn't even have DPL II, but....when I was demo-ing a receiver that did have DPL II I was very impressed with it. It sounded very similar to a multi-channel recording. It is definitely something that you should consider if you're not a 2-channel only snob.
  12. RobWil
    Mar 17, 2003
    733
  13. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    I find it very distracting listening to music in multichannel mode. I like all my action up front like its being played on stage. Some recordings do have better ambience with surround modes but most IMHO are distracting at least to my ears.
  14. ChrisHeflen
    Sep 9, 2002
    912
    Here it is straight from Dolbys' site.
    Dolby Pro Logic II is an advanced matrix decoder that derives five-channel surround (Left, Center, Right, Left Surround, and Right Surround) from any stereo program material, whether or not it has been specifically Dolby Surround encoded. On encoded material such as movie soundtracks, the sound is more like Dolby Digital 5.1 (see below), while on unencoded stereo material such as music CDs the effect is a wider, more involving soundfield. Among other improvements over Pro Logic, Pro Logic II provides two full-range surround channels, as opposed to Pro Logic’s single, limited-bandwidth surround channel.
