terence
- Nov 8, 2002
I'm sure some of you seen this, but if not good. Looks like everyone is getting into the sub game.
Model LFM-1 Specifications
Driver Type: Down Firing, 12" Long-throw Woofer
Ports: Dual
Amplifier Power Rating: 325WRMS; 1300W peak
Frequency Response: 25Hz. -180Hz. +/- 2 dB
Crossover Type: Linkwitz-Reilly 4th Order Low Pass Network
Crossover Frequency: 40Hz to 180Hz and Bypass
Phase: 0 to 180 Degrees
SPL: 115dB (subject to placement and room gain)
Dimensions: (HxWxD) 21.75” x 15.0” x 22.0”
Weight: 58 lbs
Ports: Dual
Weight: 58 lbs
