Steven Simon
- Sep 14, 1998
- Steven Simon
80 it is...
Steven- Got to admit, that I was a little nervous when you began the review with the Sony VCR and 22 gauge wire...
Yes you can on the DTS /Cirrus question. It says DTS Cirrus Cinema on the screen.
I have found that the triple crossover is just a mask for inadequate subwoofers.
Shane: Hmmm, I would have thought that the triple crossovers were a mask for less than full range speakers, not to mask a bad sub?
Please tell us what you mean?
main speakers (-3dB @31Hz)
the optimum xover is @60Hz in my listening room.
That result agrees with a rule of thumb that I've heard. The rule of thumb is to crossover at or above about twice the -3db frequency point of the speakers. That's just a rule of thumb and with all rules like this, there are plenty of exceptions.
Wouldn't it be nice if you could have different crossover settings for different sources/material? For instance setting mains to "large" for music and "small" for HT. That way with 2-channel music the sub wouldn't kick in, while with HT where critical listening isn't as big a deal the sub could take over everything under, say, 60 Hz. I'm assuming this isn't a feature of the 950 or any pre/pro for that matter?
The Anthem AVM-20 has a rudimentary capability in this area. Two different sets of settings in the setup menu can be saved, and the speaker size settings, x-over freq, etc, are stored here. Could be made easy to switch between them with remote macros, but maintaining the settings could be a chore (e.g., making a change to one set may require the same change to another). I actually used these two when breaking in my speakers. When in unattended break-in mode, I used a sub-less, large setting for the 5 channels. When watching a movie, the x-over was effective with sub. Generally, though, very basic and not to be used as an everyday feature.
I don't feel that the example provided is necessarily a good one in many cases. If one has a decent CDP and chooses to listen to 2ch music with analog bypass / direct set up on the pre/pro, the mains run large without sub (assuming the sub is not in-line with the mains, of course), independent of the digital bass mgmt settings. So you can have your cake and eat it too; no need for different x-over settings. With the 950 and its analog bass mgmt option (right?), this scenario may be a bit different.
Doug
No SACD, or DVD Audio as of yet. I suppose since I have the Panni RP91 I could give the DVD-A a try at some point.
Do yourself a favor and pick up six more audio interconnects and hook up your RP91's 5.1 analog out to the 950.
Go to www.aixrecords.com and order their sampler. You really need to hear this, particularly the Zephyrs track.
Regards - Gene
The one problem I see with a crossover for the mains is the desire to use an analog bypass mode for 2 channel stereo.
I personally wish that the 80 Hz analog crossover applicable to the 5.1 analog input was *also* available for 2 channel analog stereo bypass... Maybe for rev 2.0, or the 950's someday big brother!
I think that Gene says this, is because he, like me, already knows how wonderful the 5.1 direct input, and analog bypass modes of this unit are... simple invisible! As good as the DAC processing is, the simple pass through modes of this unit are oh so, even better! This is the reason why this unit is better, IMO, than the Ref 30 and the Lexicon DC-2, and at least the equal of the MC-1.
If I could bet, I'd say that with regard to 5.1 and analog bypass throughput for music, we are at the beginning of non-rewarding diminishing returns for all the more expensive pre/pros, starting with the Outlaw 950.(You can quote me on this!)
