Dave George
- Sep 6, 1999
I'm sure this has been asked before, so I apologize in advance, but I've been reading up and there are some things I'm still confused about.
First - the double bass problem. I'll be using bookshelf mains, so I want to use my sub for music. If I have the mains set to small and I'm in analog bypass mode, do I get double bass? In other words, does the crossover to the mains get overridden and bass information sent there as well as the sub, or does this only happen if they are set in large mode?
Second - Am I still going to need my Paradigm x-30 crossover? I know there are variable highpass crossovers on the 950, but what about lowpass?
Finally, would this work as a way to get around the double bass issue - set the sub seting to off, redirecting the sub info to the mains, and just use the low/highpass crossovers in the x30 rather than the outlaw.
Hope the above makes sense to everyone, as I'm pretty confused at the moment. TIA for any advice.
Dave
Dave
