Brian L
- Jul 8, 1998
A question for 950 owners that also have either universal players like the Pioneer 45/47/563, Denon 2900, or players that combined DVD-V with either DVD-A or SACD (like the Denon 1600).
1. Do you have any issues calibrating bass level from the analog outs of the universal players connected to the 5.1 Ext. Inputs vs. digital sources decoded within the 950?
2. If so, how do you get the bass levels balanced between 5.1 Ext. sources, and sources decoded within the 950?
This question relates to the issue that many users of these players have with low level of the sub channel (combined LFE and redirected bass, or just the LFE channel when BM is not used in the player) compared to the main channels.
My 45A exhibits this, and it appears that many owners of other players have seen this behavior as well. I have separate level trims for the 5.1 inputs on my AVR, so I currently can get around the problem easily.
But, I have gear lust. I am sitting on the fence right now trying to decide between buying a 950 (which I would use primarily as an outboard decoder with my existing AVR), or an entirely new AVR (the NAD 762 is currently high on the list).
What is holding me back from the Outlaw is that it only has a single set of global channel level adjustments, which would seem to make it difficult to get the sub/LFE channel properly balanced between sources when using one of these uni-players.
While I could adjust trims in the player, that does not appear to be the correct location for the +10 boost commonly required , since I am NOT using the BM in the player and use an ICBM for that purpose (the boost should be applied after the redirected bass is summed).
I have had some correspondence with Kevin C. Brown, who has used a 950 with a 45A, but he and I are in disagreement as to wether or not the boost is required. My tests show that it does, but he has also tested with opposite results. We are currently in a friendly disagreement on that count.
Surely there are other owners of these players that also have a 950, and surely they will have had to deal with this issue,if their player is affected.
I have posed this question to Outlaw, but have not gotten the usual speedy reply as yet.
Thanks for your comments.
BGL
BGL
