Mark JM
- Feb 26, 2002
I have a pair of NHT Ones which I mounted almost flush facing out of my shed at each corner, and they set just under the eve of the roof. Inasmuch as I have cut 2 holes in my shed walls, and have caulked around the speakers, it is not practical to bring them inside. My question is, living in upstate NY and being prone to some severe winters, should I try to cover and or insulate the speakers, or will they be fine as is? I do not know anything abt the construction of speakers, but Im concerned mainly about mositure, freezing and melting, re-freezing...
so can anyone tell me, will they survive the winter??
Mark
Mark
