Outdoor IR Products?
Discussion in 'Home Theater Projects' started by johnnyLongwood, Jun 30, 2005.
  1. johnnyLongwood
    johnnyLongwood Auditioning
    Jun 14, 2005
    5
    I have speakers out on my deck and would like to be able to adjust the volume using the remote control.
    I have a Denon 3805 receiver, but do not want to fork over $200 for the Denon RC616(IR Retransmitter) & RC617 (IR Sensor) if I can avoid it.
    My receiver is located in my den which is adjacent to my deck. I would like to place some kind of IR sensor in the window. Range from the deck to the window is
  2. DaveHo
    DaveHo Supporting Actor
    Dec 11, 2001
    605
    Get an IR/RF universal remote such as the URC-9910.URC-9910 @ Surf Remote Control I use 4 of these, one for each remote zone. They work great & are relatively cheap.
    -Dave
  3. Parker Clack
    Jun 30, 1997
    12,216
    59
    9,110
    Kansas City, MO
    Parker
  4. johnnyLongwood
    Jun 14, 2005
    5
    Thanks for the tip. I did a bit of poking around and read some reviews on the URC-9910. I found it at Buy.com for $33, just under $40 with shipping. Looks like it will do the trick. I'll let you know how it works out.
  5. Kevin_Spradley
    Kevin_Spradley Stunt Coordinator
    Jul 11, 2000
    171
    I too use the 9910. I love this remote. It is also JP1 programmable which has allowed me to fully customize this remote to do anything I want it to. I bought it from buy.com and about 2 months after I purchased it, the L2 button quit working. Even though I outside the 30 day policy, they sent me a new unit after I sent the old one in. Great remote. I use the RF feature to control my DVR in the living room while I watch recorded shows in the bedroom. (other hardware also needed)
