Are most projectors the same in that they can be used inside or out or are there specific ones for both.
I see projectors on Amazon from $69 to $1000. Epson seems to be a brand I see a lot. A boom box is what I was thinking about for sound and maybe a portable screen or even a bed sheet.
Keep it cheap, focus on it being BIG and bright rather than necessarily in HD, and make sure the audio is loud and clear enough to withstand a strong breeze!
Not to quibble with Dave, but the projector he suggested is a DLP. Those use a spinning color wheel to make a colored image rather than individual color chips. For some people, this is fine, but for others, they see rainbows on the screen during projection. Before spending your money on a DLP, you may want to visit a showroom or someone who has a DLP projector to ensure that you're not prone to rainbows.
The other thing, DLP projectors generally include very little to no lens shift, which means your placement of the projector isn't as flexible. This may or may not be an issue for you depending on your place, but you may want to use the calculator at Projector Central before buying to make sure the projectors required measurements and positioning with work in your outdoor space.
Most of the gear I use comes from other HT system inside of my home. Some of the speakers are for outdoor use but the components come from other systems that I have upgraded and moved these units to the backyard home theater.Hi All
Looking for ideas and suggestions on setting up an outdoor theater. Projector, screen, sound system.
Looking to spend about $1000.
Thanks!
