Outdoor Audio Question (1 Viewer)
StephenGencs
I am helping a friend design a whole home audio system. Everything is pretty much all set, but we were discussing the wiring of a speaker/jack outlet to the deck. He has a pretty big yard, so instead of running conduit and wire 100 or so feet, we figured it would be good to have the jacks there and just run the speaker wire when that part of the yard would need audio....
My question is....what would be the best/most practical type of outletjack to use -- binding posts? bananna jacks? Others?
Thank you much!
Stephen
JustinG
i would think the 5 way binding post plate in a weather proof box. Then you coul run your conduit from the box into the ground.
Mindy
