Drew_W
- Jul 2, 2003
Here's some background:
The system as it is now:
Pre/pro: Yamaha RXV-630
Amp: Rotel RMB-1075
Source: Denon DVD-2200
Speakers: Front L/R Energy Veritas 2.1
Centre & Rears: from Energy Take 5.2 set.
Cabling at the moment is Linn K20 to the fronts, Monster Z1 to the centre, XPHP to the rears. Interconnects are my own Belden 89259/Eichmann Bullet Plug concoctions (1695A for digital coax).
I'm going to upgrade the front L/C/R to Veritas 2.2i/2.0Ci I think...as it stands now, the centre is quite subpar for multichannel music usage...and as always, I'll go audition other stuff, but I admit my bias towards Energy and other API stuff. I'll leave this for another thread though, just thought it might be some more useful background.
Back on track ...
In analyzing my system usage, I've realized that 95% of my listening is stereo CD playback. The Denon puts out a better sound via its digital output than via analog in my system as it stands. I purchased the Yamaha as an interim preamp until I could afford something better. We're there now. My idea was to get the speakers and a processor now, and add a dedicated CD player at a later date.
Based on suggestions I've read and received, I'll quickly sum up my options as they exist in my head...I'm sure this isn't an exhaustive list.
1a) Upgrade processor to Rotel RSP-1066. Use Denon 2200 as source for now via whatever output sounds better with the Rotel.
1b) Someone suggested an outboard DAC (the Bel Canto DAC2, specifically) could be added later in lieu of a dedicated CDP to add more flexibility. Or it could be added now. I have no personal experience with the Rotel processor and don't want to bug my dealer if I have no intention of buying. The Bel Canto seems to get good review though, although it is absolutely ugly and in a monoblock like box that I have no idea where I'd put in my rack. Another option was the Musical Fidelity A3.24 if one ever pops up in Canada again. If Andrew Pratt sees this, I know you had this DAC with a Rotel processor in your system for a bit. Could you share your experiences?
1c) Upgrade to the RSP-1068. This will blow the budget entirely though.
2) Upgrade the processor to something else in the same budget bracket (used items, of course).
The caveat here is that it has to be available in Canada. Importing something of this value effectively adds ~$300CND+ to the price, so unless something is priced absurdly below market value, my options are sort of limited here. I've found a Rotel RSP-1066 here in Canada, so I have a limited amount of time to make up my mind, but I wanted to explore other options. Whatever it is, it has to have a 6 channel analog input (which means something relatively recent), DPLII (again, something recent), and then all the normal DD/DTS/etc.
3) Keep the Yamaha. Add a DAC.
I'm not really sure how this would work out. The idea of a ~$500 receiver getting a signal from a $1300 DAC and passing it to a $1500 amp seems a bit...out of balance. ($ = CND)
4) Something else. I welcome any and all suggestions.
5) A personal friend suggested keeping only the Rotel amp, selling everything else, and starting over. Not really an option in my mind, but I thought I'd throw it out there to see if someone else agrees.
The more ideas and suggestions the better. If anyone in Toronto has similar setups and would be willing to arrange an audition, I'd appreciate it.
Thanks!
Amp: Rotel RMB-1075
Back on track ...
Thanks!
