Ryan T
- Sep 10, 2001
The Topic should say "Other options besides internal bracing" but my computer messed up sorry.
Hi,
In my other tread PE 3 cu. ft. subwoofer enclosure I asked this question but got no replies so I figured I will give it another try, well here goes. I’m stuck with using a make shift car sub box for my shiva until I can get a real box and I’m wondering if there is any way I can brace the sub without having to rip apart the whole box. One idea I thought of is to get some long threaded rods and drill a hole in each side of the box then secure the rod with washers and nuts. Do you think this would work well? I also read the some people spray autobody under coating on the inside of there sonosubs to reduce resonance, even though this would take more work do you think this might work? Thanks
Ryan
[Edited last by Ryan T on November 15, 2001 at 01:49 PM]
Hi,
Ryan
