Derek N
- Jun 9, 2003
I just bought a HK AVR-325 that has OSD but not through the component hook-up. I was curious as to how those of you that have had this feature use it (if at all). I did not buy the receiver for the video swithing, although I do plan to use it. Of course I would like to use the best connection method possible which is component. Alas its noted that OSD does not work with component, only S-Video/composite.
What are the options?
Hook an S-Video cable up for set up, then connect component and lose the feature.
Can't have both hooked up at once can you?
Since I am not using a digital TV would leaving the S-Video hooked up instead of component be noticable? ( I went right to component when I got my first DVD player, never used s-video. I do however understand that the split signal of component is better, just wondering if my standard Toshiba 36" tube would show the difference)
Derek
Derek
