OSD for Onkyo 601
Discussion in 'AV Receivers' started by ChrisMcK, Feb 27, 2004.
  1. ChrisMcK
    ChrisMcK Stunt Coordinator
    Jan 9, 2003
    72
    Can anyone help wth this - I'm having trouble getting the on screen display on my tv screen - its on the frfont panel display but its supposed to be on screen as well and i cant figure it out why it isnt
    Its the Onkyo TX SR601
  2. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    I beleive you have to have a S-video running out from the receiver into the TV.
  3. Kernel X
    Kernel X Extra
    Feb 26, 2004
    24
    That is right, you have to connect an s-video cable or a regular composite cable to your tv(input) from your monitor out connection on your receiver...have a good one!
  4. Alan Wise
    Alan Wise Stunt Coordinator
    Jan 28, 2004
    236
    Kernel,
    You should also be able to connect via Component Cables (red, green, blue) provided your set has such input.
    Picture wise this is the best method.
    Good Luck, Al.
