Hello all and thanks for the add!
I'm a new guy on the forum and have some questions regarding my theater components...
Start off by listing components:
OPTOMA Projector: Model - H30
A/V Receiver: Samsung HT-C6600
First: I am wondering if possible to get OTA HD Antenna channels from the receiver to the projector and what components and wire are necessary if possible? Ive read it may be possible to hook a VCR to handle the "set top box" as a channel changer? Possible? or any other options?
Second: The blu-ray is smart enabled but I have no option on the interface to setup as a wireless network (wired only).
Therefore, I would like to be able to hook up my roku via HDMI to the receiver and project signal to screen. The setup now plays DVD's and audio fine, problem is I can't get the ROKU interface to show on projector...
MAIN QUESTION: Is this all compatible or impossible? Cheaply? What wires and adapters will i need to route VGA, HDMI, S-Vid, Composites and RCAS (whichever applicable)
Photos for reference.
Thanks in advance!
Thanks in advance!
