Optimus PB12, how would you modify these?
Discussion in 'Archived Threads 2001-2004' started by Meaux, Dec 1, 2002.
  1. Meaux
    Meaux Stunt Coordinator
    May 27, 2001
    168
    I know they are junk. Just want to tighten em' up.
    I've disconnected the x-over (250hz.) and using the 80hz. out of the Adcom preamp. I'm Powering them w/ a Adcom 555, in stereo.
    What next?
    polyfill?
    New woofers?
    Put 'em on concrete blocks?
    They are downfiring on carpet.
  2. Todd Shore
    Todd Shore Stunt Coordinator
    Jun 5, 2001
    101
    You might try playing with their height from the floor and with fill.
    What don't you like about it? Doesn't go low enough? Boomy?
  3. Meaux
    May 27, 2001
    168
    They're on the boomy side allright.
  4. Todd Shore
    Jun 5, 2001
    101
    You could line the enclosure with foam and install an internal cross brace or two. That wouldn't mess with the "design" too much and should help to tighten things up.
    Also, if you are firing directly onto carpet you might want to try some different materials under the sub.
  5. DavidY
    DavidY Supporting Actor
    Mar 19, 1999
    510
    IMO, I would try to tame the boominess with polyfill.
    Dave
  6. DavidY
    Mar 19, 1999
    510
    Sorry about the dupe.
