Optimum Height for Surround Speakers (1 Viewer)
MikeEP
Mike
Greetings to All. Have just bought Polk T15 bookshelf speakers, and a Polk PSW108 subwoofer. These now join a pair Polk M3s, and a Polk CSR center speaker. We have a rectangular living room / kitchen (great room) that I am setting this up in. Am thinking I will put the T15's aside the TV, with the M3's mounted to the wall on the sides / rear.
Was wondering if you could share what might be the optimum height to mount the rear speakers? Ceiling is flat but about 9 ft high.
And if you have thoughts otherwise, am I better off with the T15's in the front and the M3's for surround?
My thanks!
JohnRice
Bounded In a Nutshell
A Mile High
If it's 5.1, which it sounds like it is, side, maybe just slightly behind the listening position, a couple feet above sitting ear level. For years I thought rear placement was better, then discovered side is much better. If you upgrade to 7.1, then you put a pair in the rear. I also understand that if you upgrade to Atmos, you might want to lower them a bit.
zoobird
