Optimum Distance from Screen to Seat
Discussion in 'Beginners, General Questions' started by Jeff Weight, Jun 30, 2003.
  1. Jeff Weight
    Jeff Weight Stunt Coordinator
    Nov 2, 2001
    70
    What's the optimum distance from the TV screen to your seating postition. I'm looking to buy an new TV and would like the formula.
    Thanks!
  2. Scott McVicker
    May 10, 2002
    35
    I believe I read that a good ratio is 1.5x the screen size. So if you have 55 inch tv, you should sit back at least 82 inches or about 7 feet. I believe I read this in consumer reports.
  3. Roger Li
    Roger Li Extra
    Sep 26, 2002
    22
    I think a lot of it is just personal preference. I've found that 1.5x the screen is too close for me, but that 2x to 2.5x is about right (for me).
  4. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    The Viewing Distance Calculator provides these numbers:
    TV Size (Diag inches)16:9 THX Rec16:9 THX Max16:9 Max for 1080i 404.56.35.2 455.07.15.9 505.67.96.5 556.18.77.2 606.79.47.8 657.310.28.5 TV Size (Diag inches)4:3 THX Rec4:3 THX Max4:3 Max for 1080i 404.15.84.8 454.66.55.4 505.17.26.0 555.67.96.6 606.28.77.2 656.79.47.8
    The THX Rec is the distance in feet that THX recommends for movie theaters. The THX Max column is the max distance (back row).
  5. Bill_Wil
    Bill_Wil Stunt Coordinator
    May 26, 2003
    165
    I think I read that it's best viewed from 2.5 to 3 times the diagonal screen size.
    Another thing that I read said that you should sit just far away enough so that you dont see the resolution lines.
    Heres a link that will help with some of your setup and other questions...
    http://www.htadvice.com/on_setup/tvs_placement.html
