Optimal spacing between driver and base plate for downfiring Tumult?
Discussion in 'Home Theater Projects' started by Mattak, Apr 16, 2005.
  1. Mattak
    Mattak Stunt Coordinator
    Dec 15, 2003
    247
    Is there an optimal spacing between the driver and base plate for a downfiring Tumult? Or should I just try different spacings?
  2. Seth_L
    Seth_L Screenwriter
    Apr 5, 2002
    1,553
    You want there to be a larger opening than the Sd of the driver. So, if you have a driver with a 1200cm^2 Sd you want more than 1200cm^2 of opening. The more you have, the better.
    So, a Tumult has a Sd of 749cm^2. That means the moving diameter is 30.99cm. So, the circumference is 97cm. 749/97=7.72cm. I'd add in the 34mm of x-max to be safe, so you end up 11.12cm. That's 4.37"
  3. SammyXP
    SammyXP Auditioning
    Oct 14, 2005
    13
    Am I missing something? What are you calculating when you are dividing the Sd by the circumference (749/97)? Geometry class must have been a long time ago because I'm not seeing it. Seems like Sd/C simply equals 0.5R
    I'm asking because I'm building a downfiring sub and the only criteria I've found for spacing on the bottom face is the ensure it is greater than the port diameter. I've got dual 3" ports, so I've been planning on making 3.5" legs, just to be safe.
  4. Mattak
    Dec 15, 2003
    247
    Extrapolating from his post, I think what he was getting at was that you want the opening as big as the Sd of the driver, and in this case your opening can be assumed to be a cylinder wall around the edge of the driver (not sure how to make that clear with words). The radius of the cylinder is the radius of driver, but not the entire physical driver, just the cone basically, which we can call R. Since manufactures don't give you R, they give you Sd, you find R:
    piR^2 = 749
    R = 15.44cm
    R is the radius of our cylinder, so now we find the height (distance from driver to baseplate):
    cylinder area is height*circumference, H*2piR
    Sd = H*2piR
    749 = H*2pi(15.44)
    H = 7.72cm
    My Xmax is 34mm, so at full extension I'd lose 34mm of my cylinder opening, so 34mm is added to H to make up for it.
    7.72 + 3.4 = 11.12cm
    Basically, you don't want the base plate loading the subwoofer (at least not in my case I didn't).
    In the end, though, Sd = piR^2 and H = Sd/2pi, so H = R/2
  5. SammyXP
    SammyXP Auditioning
    Oct 14, 2005
    13
    Ok, I think I understand now. You're basically looking for the surface area of a cylinder around the perimeter of the effective cone area. Otherwise, the air coming from the cone face would have to compress before exiting the openings underneath the enclosure.
    Turns out not to be too big a deal for me since, for a Dayton 15" DVC, R=16.03cm and Xmax is 1.51cm, so I need 3 3/4" of height, which is only 0.25" taller than I was planning on being.
  6. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    Perhaps "Physically", the subwoofer should be 4.5" high minimum to allow for unrestricted air flow. Remember that the height of a woofer might change the frequency response in the room at the listening position. This is due to floor ceiling standing waves.
    Not that this would probably be a big factor...
