Phillip Reed
- Dec 26, 2002
Greetings. I just took delivery of my new Christmas present, a Toshiba 50H82. Hooked it up to a Toshiba SD-5109 that I've had for a couple of years now. I was running S-video into my older 30 inch tube set. For the new system, I'm using the component video and so far the results are knocking my socks off. Thanks to folks who maintain the lists here, I've already learned a lot (already set the contrast down to 35, for example). And, the Avia disk is on its way, so I'll be able to do a better setup soon.
Questions:
(1) Which output from the SD5109 would give me the best results? It's got Progressive and Interlaced as separate component outputs on the back. I thought I saw somewhere that Interlaced would give me 1080i vs. Progressive with 720p. Can somebody with experience tell me which is better? Right now I'm using Interlaced, and the picture is (to my untrained eye) very good.
(1a) Is there any way for the TV to give me the characteristics of the displayed signal?
(2) I set the SD-5109 to 16:9 output, which appears to be the only reasonable choice. The TV is set to Full and Cinema mode. Any other settings I should know about?
(3) I just parked my center speaker on top of the TV, which is where it was on the old set. Are there any advantages to using the internal speakers as opposed to an external center speaker?
(4) Any recommendations for an HDTV tuner?
Thanks in advance.
...phil
Questions:
Thanks in advance.
...phil
