Optical vs. Digital Coaxial?
Discussion in 'Archived Threads 2001-2004' started by Colin Walmsley, Jan 24, 2003.
  1. Colin Walmsley
    Sep 23, 2002
    21
    I just ordered the Denon 1600, and was wondering what would be the best way to connect it to my 1603. I would have thought an optical cable would be best, until I read somewhere that many prefer using the coaxial connection. Any suggestions? What are the audio benefits of each.
    On another note.. what analog cables should I use for the 5.1 analog? Just regular audio interconnects? Thanks for the help.
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    They both work just fine. No sonic differences.
  3. Ryan Leemhuis
    Ryan Leemhuis Second Unit
    Oct 1, 2002
    490
    I have heard quite a few people just use decent priced video cables for the 5.1 and buy 6 of them. try out accessories4less.com. Look at the AR pro series video cables.
  4. Brent_H
    Brent_H Second Unit
    Aug 14, 2002
    366
    i dont believe the 1600 has a coax.......
  5. Dave Ma
    Dave Ma Stunt Coordinator
    Jan 17, 2003
    113
    Generally speaking, when you have the choice between toslink (optical) and digital coax, the digital coax sounds better. Both carry a digital signal, but the optical signal goes through 2 extra conversions (electrical->light and light->electrical). The optical connection has shown to have more jitter problems.
    [​IMG]
  6. JasonLC
    JasonLC Stunt Coordinator
    Sep 21, 2002
    91
    Colin,
    The Denon DVD-1600 only has an optical output. BTW I notice no sonic difference between optical and coaxial on my Panasonic RP82.
  7. ReggieW
    ReggieW Screenwriter
    Mar 6, 2001
    1,571
    Colin,
    I have never heard any sonic differences between the two - and I'm talking on really high-end equipment. Optical should be just fine.
    Enjoy your DVD-1600,
    Reg
  8. Jerry Gracia
    Jerry Gracia Supporting Actor
    Oct 20, 1998
    534
    No difference.
    I'd go with coax.
  9. Dave Ma
    Jan 17, 2003
    113
    If there were no difference's they would not put both. On some receivers if you conncet both optical and coax the reciever will default the optical and go with Coax. So I quess the receiver knows which one is the better of the two(COAX). Meridian does not even offer OPTICAL connection on their DVD player as far as I know. Any pro will tell you go with the COAX every time: Generally speaking, when you have the choice between toslink (optical) and digital coax, the digital coax sounds better. Both carry a digital signal, but the optical signal goes through 2 extra conversions (electrical->light and light->electrical). The optical connection has shown to have more jitter problems.
    As I posted once before![​IMG]
  10. Reginald Trent
    Reginald Trent Screenwriter
    Feb 18, 2000
    1,313
    I believe both are offered to ensure wider compatibility moreso than and any real or imagined difference in sound.
  11. Luke_Y
    Luke_Y Second Unit
    Aug 20, 2001
    424
    Colin, no audible difference and a 75ohm video cable is usually cheaper than a Toslink cable.
    Dave, whatever differences there are (jitter or whathaveyou), there is NO audible difference.
    The redundant connections on many players are there to give it more versatility in connection to the receiver or pre-amp.
  12. Mike Matheson
    Mike Matheson Second Unit
    Jul 15, 2000
    416
  13. Patrick R.E.
    Patrick R.E. Agent
    Sep 12, 2002
    33
    There is a difference (coax and optical)
    -When your using the optical cable your using de sound decoder of your dvd player or you cd player.
    -When your using the coax cable your using your receiver or pre amp for sound decoder.
    A lot of people wont "see" the difference but there is a difference but in some situation your better with coax and in some other your better with the optical.
    In all high end pre amp and cd and dvd player there will all ways be connected by coax cable because they use the cd and dvd player for transport only so the pre amp will do the job of decoding of the sound.
    Sorry for my English... this is my second language.
  14. Carl Johnson
    Carl Johnson Cinematographer
    May 6, 1999
    2,259
    25
    1,610
    Carl III
    Your English is good but I question your logic. If you connect a cd player to a receiver using optical cable the receiver does the decoding, not the cd player.
  15. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
  16. JeremySt
    JeremySt Screenwriter
    Aug 19, 2001
    1,771
    14
    610
    Jeremy
    Not true. With Coax and Toslink, your processor decodes the digital data stream.
    Here is my .02
    Differences:
    -Toslink transfers the signal with an optical stream, not voltage.
    -It is immune to elictrical interference, a benefit if you are sending over a long length.
    -The signal goes through additional signal processing, converted from voltage by the DVD player, into an otical form for transmission, and then back into voltage by the processor. (considered a disadvantage by most)
    -Damage or scratching to the the lenses on either end of the cable, or a severe bend in the cable can result in signal degredation.
    What I mean is, a $20 toslink and a $20 Coax will probably sound the same. More expensive Toslink will most likely be built better, but not sound better. All toslink pretty much sounds good to me. Differnet Coax cables will yeild different results in sound. There are terrible ones and great ones. This has been my experience.
    I think Coax is far better, but it can take double the investment over Toslink to hear an appreciable difference.
  17. Chad Ellinger
    Chad Ellinger Second Unit
    Jun 18, 2000
    269
  18. TimothyE
    TimothyE Stunt Coordinator
    Dec 31, 2002
    104
    One of the more informative threads I've seen on this subject can be found
    here.
    All the best,
    Tim
  19. Angelo.M
    Angelo.M Producer
    Aug 15, 2002
    4,007
    No appreciable difference. Either will do.
  20. Elbert Lee
    Elbert Lee Supporting Actor
    May 24, 2000
    501
    if there is no audible difference, go with the one that's cheaper and that's at least Scientifically better or at least THEORETICALLY BETTER: the digital coax.
    you have no downsides to opting to go with coax, unless you plan to run the cable for long distances.
    I personally have heard differences on my system with different coax cables vs. optical cables. In two and multi-channel critical listening sessions, I have always favored the coax over optical. THe differences were much harder to tell with movie soundtracks.
    When auditioning various optical cables, I could not really tell a difference between them.
    ELbert
