Optical or Coax?
Discussion in 'Archived Threads 2001-2004' started by David Ely, Oct 3, 2001.
  1. David Ely
    David Ely Supporting Actor
    Sep 1, 1998
    753
    I was wondering what type of digital cable people have connecting their DVD player the their receivers. I currently have an optical cable, but I'm thinking about going to coax. Why? Well ... Why not? Hehehe [​IMG]
    So ... what do you have?
  2. Michael Lee
    Michael Lee Supporting Actor
    Jan 7, 1998
    652
  3. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    Coax...
    Because you can use any old Composite Video cable (which i have plenty of), and even if you have to buy it, its cheaper than an optical cable... [​IMG]
    The So Family Home Theater!
    http://www.multimania.com/sonick182/ht/index.html
    You're all entitled to your opinion, but you're all wrong!!! - Paul Dalmine
  4. Brad_W
    Brad_W Screenwriter
    Sep 18, 2001
    1,358
  5. Jeff_A
    Jeff_A Screenwriter
    Mar 6, 2001
    1,454
    Optical here... Can a hardware expert please give us a definitive answer as to which is best and why? There must be some way to test the actual efficiency of each.
    The Dark Tower
    [​IMG]
    Fearless Vampire Killers (1967)?
  6. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
  7. James D S
    James D S Screenwriter
    Nov 14, 2000
    1,000
    Coax.
    1. You can use any RCA cable you have laying around the house.
    2. Optical cable is expensive as is not laying around the house.
    3. Optical provides no bandwidth advantage were the audio bitstream is concerned. Max is max regardless of medium.
    4. Optical breaks very easily, coax does not.
    But, optical does look cool.
  8. JohanK
    JohanK Second Unit
    Jan 22, 2000
    478
    I use both with a DVD player but am moving to HTPC so am limited to coaxial (which I have no problem with).
    http://www.hometheaterforum.com/bbs/equipment/28687.html
  9. Alex Spindler
    Alex Spindler Producer
    Jan 23, 2000
    3,971
    Right now I am close to port exhaust on my receiver, so I'm using both. Both sound excellent to my ears!
    Bombardment Society - Member
  10. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    110
    I use metal coat hangers!!
    Hey it's digital, it's either there or not !!
    LL cool B
    Coax usually [​IMG]
  11. Rob Tomlin
    Rob Tomlin Producer
    Jan 8, 2000
    4,505
    From what I recall about this topic on this forum previously, it appears that there is no measurable advantage to optical over coax.
    Coaxial is much less likely to "break" than an optical cable, so Coax it is for me!
  12. SteveA
    SteveA Supporting Actor
    May 25, 2000
    700
    I've been using optical for 2 years, but hell, if the cable ever breaks, I'll switch to coax at that time!
  13. ChrisV
    ChrisV Second Unit
    Mar 25, 2001
    484
    Optical... no reason [​IMG]
  14. Brent Cantrell
    Brent Cantrell Stunt Coordinator
    May 7, 2001
    244
  15. Keith_R
    Keith_R Screenwriter
    Jun 16, 2001
    1,172
    110
    FL
    Kyle
    I use coax. [​IMG]
    -Keith-
  16. KeithH
    KeithH Lead Actor
    Mar 28, 2000
    9,413
    I use a coaxial digital cable for my DVD player. I used to use an optical digital cable, but when I moved and shifted some components around a few months ago, I had a free coaxial digital cable lying around, so I started using it. I have not observed any difference in sound quality between the two cable types. The coaxial digital cable is more sturdy though, which makes me feel better.
    Many audiophiles prefer coaxial digital cables. Besides being more sturdy, they often say that they sound better than optical digital cables. I don't know why this should be so. It is true that the vast majority of audiophile-oriented CD players only have a coaxial digital output.
    My:
    HT Pics ; Equipment List ; DVD Collection ; LD Collection
    KeithH: Saving the Home Theater World Before Bedtime
    [Edited last by KeithH on October 04, 2001 at 09:24 PM]
  17. AaronMK
    AaronMK Supporting Actor
    Oct 30, 1999
    768
    Orlando, FL
    Aaron Karp
    Coax for me.
    Cheaper, more sturdy, and I have not heard of anyone being able to hear a difference.
    My DVD's
    If a movie is not available in OAR, than it might as well not be available at all.
  18. John Besse
    John Besse Supporting Actor
    Jun 22, 2000
    569
    Trinity, FL
  19. William Ward
    William Ward Supporting Actor
    Mar 1, 2000
    701
    How about "Optaxial" connections?? [​IMG]
    Actually I get all my digital devices together and connect according to what inputs/outputs I have. The only time I have a choice is my DVD player and I use coax. It's the only input left after my AC-3 LD connection(coax), DTS LD connection(opt), and HDTV receiver connectin(opt).
    William
    Go Bucs!!
    MyDVDs
  20. Kevin M
    Kevin M Producer
    Feb 23, 2000
    5,172
    2
    My DVD player will pass a digital signal through both outputs so I borrowed my friend's Monster Toslink and through video switching I did a side by side comparison between the optical and my Monster Coax and I found that for 5.1 material (I.E. DD, DTS) there was no difference at all but with PCM (CD's) the coax had a much more warm sound to it where as the Toslink sounded "tinny" or hollow and lacking the bass push (in the low end) that the coax "seemed" to have. I brought my mom over and asked her if she heard a difference and she (being 65) said that the "one sounded cold, but I like that other one", she had picked the coax.
    This has been my experience anyway & I don't understand how it could be because a bit is a bit, right?.
    -Kevin M.
    I can brave the nastiest weather, even when it's eighty below.
    My Pa was an Elephant, but that's irrelevant,
    My Ma was an Eskimo."
    - Cannibal the Musical.
