optical input????please help
Discussion in 'Archived Threads 2001-2004' started by dee will, Jul 7, 2002.
  1. dee will
    dee will Agent
    Jun 29, 2002
    25
    is the optical input for my dvd player control the audio and video or just one of them??and is that the best way to connect your dvd to the reciever???ok thanks in advance
  2. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    1) Optical cable carries Audio Only.
    2) The question about "best" is an issue of what you are comparing to.
    Optical and Coax digital connections are essentially identical in "quality". But a digital connection of either type will be better than the analog connection, as a digital connection is the only way to get 6 channel dolby digital or DTS sound (the stereo analog connections will not provide this).
    See the info in the FAQ AND PRIMER in my sig, where these types of issues are covered pretty extensively (why doesn't anyone read this thing!?!).
    [​IMG]
    General Hookup Tips by Steve Berger
    Options for Routing Audio & Video by Ted Lee
    Digital Audio: Optical Connection vs. Coax connection by Neil Joseph
    Different Video and Audio connection cables and types by Chella
    -Vince
  3. Bruce Chang
    Bruce Chang Second Unit
    May 10, 2002
    283
    Optical is audio only
    Component is Video
    Composite is Video and Audio
    Coaxial is audio
    S-video is of course video [​IMG]
  4. dee will
    dee will Agent
    Jun 29, 2002
    25
    thanks a lot for the quick response..i love this website and think everyone is extremly helpful...thanks Vince
  5. Vince Maskeeper
    Jan 18, 1999
    6,499
    Technically speaking composite is video only. You can get a set of AV lines with 3 cables (Yellow, White, Red style)which carry composite vid along with analog audio- however the video is the only part that is really "composite"- and you can just as easily have a video only line.
    If you run a single composite video line from the source to the set, you will not get audio (which is what your post might mistakenly suggest).
    -Vince
  6. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
  7. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
