Optical cable question
Discussion in 'Archived Threads 2001-2004' started by Dalton, Oct 11, 2001.
  1. Dalton
    Dalton Screenwriter
    Aug 19, 2001
    1,198
    5
    Rhode Island
    Dalton
    This might sound dumb but I need help with using an optical cable. I have only used coax until now. Just got an RP56 dvd player and it only has an optical connection. My question is, do i take the little rubber pieces off the ends of the optical cable or do they go in with them on? Thanks in advance. It is an AR optical cable by the way if that makess a difference.
  2. Dalton
    Dalton Screenwriter
    Aug 19, 2001
    1,198
    5
    Rhode Island
    Dalton
    Nevermind stupid me figured it out all by myself...lol. Forget i asked.
  3. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Brett Andrew DiMichele
    Dalton,
    The only stupid question is the one that is never asked.
    Hey you got a good Tos Link there... I use AR's cables as
    well as thier speakers and couldn't be happier..
  4. Matty B
    Matty B Stunt Coordinator
    Aug 27, 2001
    227
    ARs and RCA make the best optical cables IMO. It's not humble. [​IMG] I have a 12 foot AR Optical cable and it works great. I don't think that question is stupid, it's not like it comes with instructions.
    On a side note. In a previous digital is digital discussion someone said that the signal is all or none, and I would like to state that although THEORHETICALLY that is true, my friends optical cable had light showing through, but it did NOT work. We switched it to an RCA Optical cable and BAM it was working.
