BruceD
- Apr 12, 1999
This is not verified in the audio domain, but in the data domain I have had problems overdriving (reflections) the optical transceiver with too short a cable (less than a meter).
Have you ever heard a really high end stero, and been floored by the soundstaging and imaging? (If not, you really should. ) Well, I hate to be the one to break this to you, but there's no way to measure thatWell you can actually measure high end stereo, the measurement unit is money... BTW, you are right, you can't measure how you describe something. You can measure and understand what causes it to sound that way.
Surely these cable / power cord debates can be ended by someone with appropriate equipment and testing techniquesYou would think so. But it doesn't work that way. The debates have gone on as far back as I can remember (20 years?) and will probably continue.
But hopefully we have described "optical cable differences". Whether those contribute to better soundstage or anything else is a whole 'nutter trip.
An no chu, you'll have to sit in the trunk. Mommy want's some peace and quiet for a change.
aldamon:
Have you ever heard a really high end stero, and been floored by the soundstaging and imaging? (If not, you really should. ) Well, I hate to be the one to break this to you, but there's no way to measure that.
LarryTo a relative HT outsider, computer enthusiast, that sounds like complete and utter balogna. That's just the "mystical" HT culture talking. Call me a cynic, but there's no magic in HT, only hardware. I will NEVER be floored by anything (ESPECIALLY cables) unless:
A. someone can tell me WHY something is better using something other than paper specs and magical descriptions
B. it has been compared conclusively to other products and an exact price / performance ratio is established
Otherwise, I'd always assume the price tag, my brain and the environment are playing tricks on me.
In your example, I'm sure that high-end setup sounds great, but why and how much better is it than other (perhaps) less expensive units? Are you saying that the high-end (high $$$) cannot be matched by another unit just because they sound good? Let's go back to cables here. There has to be a reason something sounds better and it has to be measurable or comparible to other units.
I want to see a cable shootout. Otherwise, it's AR cheapos for me until I see a compelling reason to switch. I say this as a smart CONSUMER first and a hobbyist second.
