marbletulip
- Nov 24, 2006
- Aaron
I recently solved the problem of getting my JVC TH-C50 to work as as the default sound sytem for my cable, DVD and Xbox audio, but I now have a new problem.
I have the JVC hooked into my Samsung LCD via HDMI for the DVD playback and I have an optical digital cable running from the optical OUT on the tv to the optical IN on the JVC. That way, whatever is playing on the tv has the audio sent to the stereo speakers. However, on about 90% of the cable channels, the actual audio is lagging behind just slightly less than half a second where it should be according to the video source - definitely noticable and definitely annoying.
Will a different brand of optical cable possibly solve this? I'm using a $15 Phillips. Is there something else I can try?
