opt cable problem
Discussion in 'Accessories, Cables, and Remotes' started by Sheldon-m, Nov 24, 2003.
  1. Sheldon-m
    Sheldon-m Stunt Coordinator
    Oct 22, 2003
    217
    I have my dvd hooked up to my tv for component video. but i have my audio going out with a opt cable to my rec. it plays fine with dvds but with music it starts clipping. what can i do?? i have onkyo 601 Thanks.
  2. AlexanderS
    AlexanderS Second Unit
    Oct 26, 2003
    262
    Thats odd. Sounds like a source problem. What are you using to play the CD's? I think that if it were the receiver it would be screwing up with all interfaces.
  3. Sheldon-m
    Oct 22, 2003
    217
    I am using my dvd player. I'm using my opt out(dvd) to my rec input(opt 1). i have my component going straight to my tv and sending my audio to the rec. i dont know what the problems. you think it is the signal coming from the dvd?
    should i go with coax. thx
