Oppo dvd player work fine on Bravia?
Discussion in 'Beginners, General Questions' started by Darren.T, Nov 30, 2005.
  1. Darren.T
    Darren.T Auditioning
    Nov 16, 2005
    9
    Hi,
    I just want to confirm the Oppo dvd player will work fine on the V series 40" Sony Bravia tv, the res is 1366x768 and has HDMI input.
    I assume the 1366x768 res would use the 720p up conversion on the Oppo player?
    Darren
  2. Otravez
    Otravez Auditioning
    Jan 17, 2004
    6
    It sure will. Just get a DVI/HDMI converter and set the DVD player to output 720p and you are set.
  3. Paul_C
    Paul_C Stunt Coordinator
    Mar 5, 2000
    66
    Make sure you have the latest firmware update for the DVD player. I know they put one out not long ago.
    Good luck.
    Paul.
  4. Darren.T
    Nov 16, 2005
    9
    I just ordered one two days ago, im sure it will have the latest firmware?
  5. Reginald Trent
    Reginald Trent Screenwriter
    Feb 18, 2000
    1,313
    How can you tell if the player has the latest firmware? Where can you get it if needed?
  6. joseph westcott
    joseph westcott Second Unit
    Oct 24, 2005
    355
    Otravez (once again),
    Are you saying you have the same Brava display and Oppo DVD player combination and that it works?
    Thanks.
  7. Jeremy Little
    Jeremy Little Supporting Actor
    Jun 9, 2001
    770
    I'm sure they are just assuming that it works. I'd hold off until you talk to someone who has tried it. I was going to buy one for my 50" SXRD until I read about the troubles they were currently having with it. I'm holding off for a firmware update.
  8. Paul_C
    Mar 5, 2000
    66
