Opinions or experience, on buying damaged speakers?
Discussion in 'Speakers & Subwoofers' started by SeanAH, Feb 10, 2006.
  1. SeanAH
    SeanAH Stunt Coordinator
    Dec 2, 2005
    50
    Ive seen a couple interesting auctions on auction sites. They were of brand new damaged speakers. Now according the auction, the damage is just cosmetic to the box area, no damage to the woofers or tweeters. They were tested, and work fine. Some of the sellers have 1000's of feed back with a almost a 100% positive feedback to give me some more reassurance.
    But heres what Im wondering. If you think the speaker was dropped or hit hard enough to break off a corner. Or break the pegs off the bottom. Would it affect the woofers or tweeters, even if they were not damaged? Have you had any experience with buying speakers similar to this?
    I really tempted to give it a try, since I might be getting the speaker 4x cheaper than retail, but im not sure how much of chance I would be taking..
    Thanks for any feedback.
  2. Jongyoon Lee
    Jongyoon Lee Stunt Coordinator
    Dec 3, 2002
    125
    Even if there is no physical damage to the drivers themselves, the structural integrity of the cabinet itself will have an impact. How would that translate to the sound is yet up in the air. If it's a cheap speaker with particle boards glued together in a mass produced factory, small imperfection in the case would probably have little effect on the sound. On the other hand, hand made or hand tuned cabinet could reveal imperfection caused by the damage.
    If the value is 25% of the retail, I'd agree with you it would be pretty tempting. The other day I saw inoperational Mark Levinson No. 331 dual mono going for ~$1,000. It was pretty tempting for me too. The worst case I could think of would be a lightning surge that blew the fuse, or using incorrect voltage from the wall outlet, which probably won't cost another $1,000 to fix.
  3. SeanAH
    Dec 2, 2005
    50
    Thank you very much for the feedback.
    How sensitve are tweeters if the box were to experience a hard hit. I imagine they are a lot more sensitve than woofers.
    Anyone else with some feedback, I would greatly appreciate it, Im still heavily debating these speakers.
  4. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Is there a warranty with the speakers? Why don't you post a link.
  5. SeanAH
    Dec 2, 2005
    50
    Not sure ill ask, I cant post any links until I hit 15 posts.[​IMG]
  6. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    be creative and use the word dot instead of .
  7. SeanAH
    Dec 2, 2005
    50
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    It appears that the screws that held the base went right through the bottom box. So it makes me think it was crushed by something heavier. If it was dropped it would think it would have experienced more damage at the bottom.
  8. Jongyoon Lee
    Dec 3, 2002
    125
    It looks like most of the damage is cosmetic, except for the structural damage at base. Without sturdy base the speaker may resonate and cause strange boomy sound at certain freq. I do not know how easy, or if it's even possible to repair the base.
    Here's the thing though. If the original price was $1000 and you can get them for $250, chances are they will probably sound better than any $250 speakers you can buy brand new.
  9. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    jong gives good advice. May be worth the project if you're into that kind of thing. That kind of damage maybe wouldn't be so severe if it happened not in a well protected shipping box, but if they were packed well in a box and that kind of damage occurred, that seems to indicate a pretty huge fall of some kind. It still may be a fun and worthwhile project purchase, but it's possible that a sever enough shock could have damaged things like the crossover or other things glued like the VC in the driver etc.
    It's a risky move, but if the savings are significant enough it might be a good deal. But beware that you may or may not have to look into fixing crossovers or drivers perhaps. Hopefully it's just mainly the cosmetic damage.
    I also just now see that it seems to have integrated powered sub drivers in there, which adds to complications because of extra components there that may have been damaged. It just increases the riskiness, but still., could be a steal!
  10. AlbertD
    AlbertD Stunt Coordinator
    Dec 13, 2004
    135
    Those look to be Polk LSI25's. Retail around $1300 each, street price around $850-$550 each. So factor that in when you make your decision.
    Also factor in what you will be using them for. For mainly music then built in powered subs can be a good thing, if mainly HT then if you get a seperate subwoofer those built in subs may not be such a good thing.
  11. SeanAH
    Dec 2, 2005
    50
    Yes, they are lsi25's I saw they are going for 2500 a pair on the tweeter website.
    I mainly going to use them for movies which I usually watch a lot of, I may listen to some music, but only 5-10% of the time. So you say those subs really dont make a difference. If I get a sufficient sub? I plan to get a svs or hsu sub when I come across a good deal on one.
    Ive been constantly thinking about this the whole week. The auction ends tommorrow. Shipping will be around 180, so even if the seller would refund the money if they didnt function properly. It probably wouldnt be worth it to eat shipping, and pay for shipping back.
    Thanks for all the feedback so far. I guess Im going to have to sleep on it one more night.
  12. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    They really look like they've had the shit beat out of them.
