Yeshwant Muthusamy
- Dec 15, 1998
I'm in the market for a front projector and was all set on the Sanyo PLC-XP21N (LCD) when I stumbled upon the Sharp PG-M20X (DLP). It has been advertised as an ultra-mobile business projector, but its specs seem very good (have not seen it yet) for home theater.
Has anybody experienced this projector with video sources? I have not been able to find any reviews of it yet.
It costs about $1600 less than the Sanyo ($2799 vs. $4399), has a DVI input, better contrast ratio (1000:1 vs. 700:1) is slightly less noisier (37 dB vs. 39 dB) and has a USB connection. It is also 2.5 times lighter than the Sanyo (5.8 lb vs 15.2 lb). It loses out on the brightness (1900 vs. 2500 lumens) a bit and has only a manual focus lens and fixed keystone correction. Both projectors are XGA (1024x768) and are HDTV compatibile (480p, 720p, 1080i). The Sanyo can even handle 1035i (not familiar with that one). If I get the Sharp, I can use the $1600 towards the screen (looking at the Da-Lite Model B Matte white 100" diagonal screen), and audio racks.
But, none of this matters if the video image on the screen looks bad. Any comments on the notorious DLP rainbow effect with the Sharp? Or, the screen door effect with the Sanyo?
I will be visiting one of the local dealers for a demo, but thought I'd poll the group to get other first-hand opinions as well.
Thanks for your time,
Yeshwant
Yeshwant
