Opinions on Technics amplifiers?
Discussion in 'Archived Threads 2001-2004' started by Manuel Delaflor, Dec 28, 2001.
  1. Manuel Delaflor
    Manuel Delaflor Supporting Actor
    May 25, 2001
    657
    I just bought a used SU-X302. It appear to be a 30W/c and it says New Class A on the front.
    Any info is appreciated!
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,100
    33
    Katy, TX
    Wayne
    Sounds like some of their older, early-to-mid 80s gear. Good stuff!
    Happy Holidays,
    Wayne A. Pflughaupt
  3. ChrisAG
    ChrisAG Supporting Actor
    Aug 26, 2001
    503
    What's their new stuff like? It's inexpensive, but they did all right by Consumer Reports magazine (take that as you will, but CR rated the Onkyo 696 tops among models tested, which, given the models tested, I would agree with).
  4. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Technics, IMHO, are like a Sony. You can pick a few out that are good every once and awhile.
    Yet I don't know your model, sorry!
  5. Arthur S
    Arthur S Cinematographer
    Jul 2, 1999
    2,568
    The '80s amp you bought is different than recent Technics amps. The important thing is does it do what you need it to do without any problems. Few members of this forum ever had one of these "new Class A" amps and I think you have heard from those that do. After you have used it for 3 months you can give us an update.
  6. Razvan V
    Razvan V Stunt Coordinator
    Aug 28, 2000
    164
    I've owned a Technics SU-V76 New Class A amp since 1988. It's made in Japan, very good, no problems at all.
    Razvan
  7. Sihan Goi
    Sihan Goi Second Unit
    Nov 2, 2001
    442
    I'm using a pair of Technics preamp + power amp setup. The preamp is the SU-9011 and the power amp is the SE-9021. The finish has corroded a bit, and the volume control makes a kinda crackling noise, but it still runs fine.
