Mark.Louis
- Oct 10, 2002
Am new to the DIY world and am probably asking a question covered earlier, so please forgive me. I am doing my first subwoofer using Tempest in sealed box (can't get away with size of a vented design). I have basic tools now (circular saw with straight edge, drills, orbital sander, and maybe getting a router).
What I don't have are any clamps, and based on my visit to lowes and HD, they can get pretty expensive when large enough to hold a SW box together.
With 3/4" MDF, will using wood screws hold the butt joints together sufficiently tight/strong enough while the glues dries. Aside from percpetions of this "low rent" approach (vs. elegant approach of doing DAdoes, discuits, clamping, etc). are there any sonic or structural problems that arise from using wood screws? For example, will the box vibrate more with screws?
Thanks for the input. For those who recommend the glue and clamp method, any advice as to where to buy clamps more cheaply than HD will be greatly appreciated.
Mark
Mark
