Opinions on new Polk system...
Discussion in 'Speakers' started by Lev-S, Jan 3, 2004.
  1. Lev-S
    Lev-S Second Unit
    Jun 29, 2003
    324
    Since I get %40 off all Polk stuff where I work, I've decided to stick with them for my system upgrade...
    Current
    Polk R50 Towers (Fronts)
    Polk CSi30 (Center)
    Polk R20 Bookshelves (Surrounds)
    Polk PSW350 (Sub-Woofer)
    New
    Polk RTi6 Bookshelves (Fronts)
    Polk CSi5 (Center) - Too much for fronts? Thoughts?
    Polk RTi6 Bookshelves (Surrounds)
    Polk PSW350 (Sub-Woofer) - Or better if feeling like it. Any thoughts on Polk or Velodyne subs?
  2. GrahamT
    GrahamT Supporting Actor
    Sep 13, 2003
    556
    That looks good. The RTi6 and 4 will match well. The CSi5 is not too, much. THe center is the most important for HT. You could go with a CSi3 though. As for the sub, Polks aren't a good value IMO. Velodyne will be better and I assume you get a discount on these as well. Also consider Paradigm subs, even though you dont get a discount they are still a very good value in Canada.
  3. Lev-S
    Lev-S Second Unit
    Jun 29, 2003
    324
    The CSi3 is actually a worse center than my current one CSi30, according to the specs. And assuming that the manufacturer is same, the performance must therefore be worse.
    So bookshelves will work well in place of towers IYO?
  4. GrahamT
    Sep 13, 2003
    556
    I wouldn't say it is worse. I also have the Csi30 and like it but dont judge it on specs alone. It is (CSi3)very similar with an upgraded tweeter(vifa I think). THe CSi5 is better though but either will match the new RTis better than the CSi30. You could use it for a rear center.
    If you get a good sub and use bass management setting the speakers to around 100Hz or so there is no advantage to a tower.
  5. Wayne A. Pflughaupt
    Aug 5, 1999
    6,098
    32
    Katy, TX
    Wayne
    I think I’d pass on the sub for sure. Polk subs are pretty much the bottom feeders of the variety.
    Wayne A. Pflughaupt
  6. Jeff W.
    Jeff W. Stunt Coordinator
    Dec 21, 2003
    141
    Those are good bookshelves and will work fine for HT/movie applications if used on "small" with a good subwoofer. However if you're like me and prefer un-modified pure stereo mode for music, then full-range towers would be a better choice. To that end, I have the Polk RTi150's and love them. I also have the CSi30 center and so far, it's been able to keep up with the towers for movies.
  7. Lev-S
    Lev-S Second Unit
    Jun 29, 2003
    324
    Now I'm thinking Polk RTi8 or RTi10 towers...
  8. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
    I agree! If you can "swing" the Velodyne I would go that way.
    But then again there are many different brands out there to consider too.
  9. Dave Shepard
    Dave Shepard Agent
    Sep 30, 2003
    39
    Do the 8's they make for real good HT/music fronts, better then the 10's because of the 2-mids. I have a polk HT set-up with 70's as fronts and love-em.
    Dave
