RichardFlores
- Oct 29, 2003
I just bought this big screen on Saturday and must say I love it. I am getting my digital cable/HDTV set up tomorrow. I was watching lord of the rings (twin towers) last night.. and WOW..the screen is awesome! The sound of course could be better however must do for now. I was hestiant to get it because the reputation of RCA howver this screen had the best picture of all the screens I saw (except plasma but damn close). I did however buy a 2 yr extra warranty just in case!
any opinions on this TV?? reviews??
Features:
52" Diagonal 16x9 HDTV Monitor with Integrated DVD
Integrated DVD Player
AVR™ (Accurate Visual Reality) Picture Projection System
Progressive Scan
3D Y/C Digital Frame Comb Filter
CinemaScreen™ Floating Picture Screen
Dual HD Component Inputs (SYNCROSCAN™)
DVI Input with HDCP - New Connectivity
Specifications:
Screen Size - diagonal (inch): 52
Category: HDTV Monitor with DVD
Aspect Ratio: 16x9
CRT / Light System: AVR™ (Accurate Visual Reality)
Hybrid Lens System: AVR™ 4-Element
Color-Corrected C Elements
Dynamic Focus
Convergence: Intellifocus™ Digital Auto
1st Surface Reflective Mirror
Screen Type: High Gain, High-Resolution
Protective Shield
Video Noise Reduction: Adaptive
Progressive Scan
Scan Rate Converter
Comb Filter: 3D Y/C Digital Frame
3:2 Pull Down
Adjustable Color Temperature
Auto Color Balance (AKB)
Dynamic Color Stretch Circuitry
Scan Velocity Modulation - SVM
Contrast Expand (B&W Stretch): Low/Med/High
Format Control: Zoom (6 Modes)
Automatic Letterbox Detection
Picture Presets: 6+Personal
Viewing Angle: 160 degrees
Horiz Resolution (Picture Width): 1200
Picture Power (watts): 42
Wide Band Video Amplifier
SOUND
Sound Type: Broadcast Stereo w/dbx* Noise Reduction
Second Audio Program (SAP)
3D Audio Surround Processor: Virtual Dolby®
Tone Control: 5-Band Graphic Equalizer
Balance Control
Front Speakers (number): 4 - 2 Tweeters, 2 Mid-Range
Fully Enclosed Speaker System
Total Watts: 20
Channels/Watts: 2 Channels, 10 Watts Per
Sound Logic™ Audio Leveler
Sound Presets: 7 Modes + Personal
Headphone Adjustments
Dolby® Digital Pass-Through: From DVD
RECEPTION
Tuning Capability: NTSC 2-Tuner
Digital Cable Capatibility: YPrPb/DVI*
HD Ready
CONVENIENCE
Interactive Set-up with Menus
Power ON Indicator: Blue LED
Auto Channel Search
Multilingual On-Screen Displays: English/French/Spanish
One Button Launch for Inputs: Auto Tune
ENERGY STAR® Qualified
Channel Labeling
Commercial Skip: Skip to POP
Parental Control (V-Chip)
Picture Reset
Picture-in-Picture: 2-Tuner with POP
Picture Freeze
Picture Memory Presets for Video Inputs
Timers: Clock/Sleep/Turn-On
REAR CONNECTORS
RF Input (Antenna): 1
Audio/Video Inputs (Composite): 2 Left and Right Audio, 2 Video
S-Video Input: 2 - Auto-Detectible
Component Video Input (YPrPb): 2 - SYNCROSCAN™
DVI-HDCP: Digital Visual Interface: 1 DVI-HDTV
Sub Woofer Output: RCA Phono
Audio Outputs (Left and Right): 2 Sets - Variable & Fixed
A/V Outputs (Composite): 1 Set - L&R Audio + Video
DVD A/V Outputs: SP-DIF, Left + Right Audio, Video, S-Video
Audio Output (Coaxial/Optical): SP-DIF From DVD
Amplified Speaker Outputs: L & R Front or Surround
Gold Jacks
FRONT CONNECTORS
Audio/Video Inputs (Composite): 1 Left and Right Audio, 1 Video
S-Video Input: 1 - Auto-Detectible
Headphone Jack: 3.5mm Stereo
SPECIFICATIONS
Color, Overall (Screen Frame for PTVs): Gloss Black
Color - Center Panel (PTVs): Brushed Anodized Aluminum
Color - Speaker Grill (PTVs): Black
Color - Base Board (Toe Plate) (PTVs): Black
Color - Back: Cool Gray
Product Size (WxHxD) inches: 48 3/4 x 51 3/4 x 22 3/4
Weight: Product lbs: 153.1
REMOTE CONTROL
Model Number: RCR160TALM1
Type: Universal Partially Backlit
INCLUDED ACCESSORIES
Instruction Book Languages: English/French
OPTIONAL ACCESSORIES
Component Cabinet: RAV100SS
DVD CAPABILITIES
Compatible with Audio CDs
CD-R/MP3 Playback*
CD Format Compatibility: CD, CD-R, CD-RW, CD+RW
DVD Format Compatibility: DVD-R, DVD-RW, DVD+RW
Progressive Scan Picture
Screen Format Selection: 4x3 and 16x9
Frame-by-Frame Advance
Intelliseek® Scan Modes: 3x, 6x, 15x, 30x, 60x
Slow Motion Speeds: 1/2x, 1/6x, 1/12x
Multi-Zoom Function: 1.5x, 2x, 4x
FOOTNOTES
* - DVI - Assumes cable companies will use these standard connections for transferring the output of the box to the display device.
* - CD-R/MP3 - Disk must be finalized or closed.
Features:
Progressive Scan
Specifications:
Aspect Ratio: 16x9
Dynamic Focus
Protective Shield
Progressive Scan
Scan Rate Converter
3:2 Pull Down
SOUND
Balance Control
Total Watts: 20
RECEPTION
HD Ready
CONVENIENCE
Auto Channel Search
Channel Labeling
Picture Reset
Picture Freeze
REAR CONNECTORS
Gold Jacks
FRONT CONNECTORS
SPECIFICATIONS
REMOTE CONTROL
DVD CAPABILITIES
CD-R/MP3 Playback*
FOOTNOTES
