Opinions on Mits 55in Gold Wife want MORE features?
Discussion in 'Displays' started by DanielKellmii, Aug 20, 2004.
  1. DanielKellmii
    DanielKellmii Supporting Actor
    Feb 5, 2004
    524
    Mitsubishi 55 in Gold Plus RPTV
    I showed my wife the Mits 55inch silver series TV ($1298) and thought that would be an acceptable compromise between my wifes wishes and my own. She turns around and point to the Gold Plus series ($1798) and says she wants something with a built in HDTV tuner. "One less thing to cluter up our house."
    Uhhhhhhhhhhh.....OK
    Then I showed here the 65 inch and just got a dirty look. I had to try.
    Anybody out there have any opinions on that particular TV?
    Yes, I know that it is last years model, but so what? I will be able to recieve over the air HDTV broadcasts. I just won't pay for HD cable now because I get standard cable with my subdivision already. Any calibrators out there have anything to say? Yes, eventually I will get somebody to callibrate it.
    Thanks.
  2. Shane Martin
    Shane Martin Producer
    Sep 26, 1999
    6,017
    I bought the set below that(Silver Plus) and love it. I didn't find the extra features in the 613 warranted the extra cost. It has firewire but I don't have a DVHS player or a Camcorder with Firewire. $1798 is a great price on the Gold Plus. I paid $1699 for my Silver Plus.
    Couple of things:
    1. Lower the red down when you get it.
    2. Take off the screen protector if you can. HUGE difference.
    3. Turn off VSM
    4. do a convergence then do it again about 3-4 days later(it will drift early on). Mine hasn't drifted from the 2nd convergence I did. That was about 5 months ago.
