Opinions and advice sought....!
Discussion in 'AV Receivers' started by luyen, Jan 15, 2006.
  1. luyen
    luyen Auditioning
    Jan 14, 2006
    4
    Hey there everyone,
    Hey everyone,
    I'm about to upgrade from my 15-year old 2 channel hi-fi. The nice thing about my setup is that I Haven't had to think much about it for over a decade. The bad thing is that the world has passed my system by! I'd like to upgrade my 2 channel setup while putting myself in position to go surround. But I don't want to break the bank. I'd like to spend no more than $2K, but I'm happy to spend that simply on upgrading my 2 channel sound and position myself for 5.1/7.1 down the line. Currently, I have an Adcom pre and an Adcom 100 watt 2 channel amp. My thinking is to go with a really good HT receiver and use my Adcom amp to drive the front 2 channels, upgrade my 2 front speakers, and eventually get sub, center and rears.
    I am probably 80% music, 20% HT, and I'm a pretty picky listener with eclectic musical tastes.
    The two options I'm considering (but would value each of your personal solutions) are the Rotel RSX-1056 or the Outlaw 1070. For speakers, though it's hard to buy speakers I haven't heard, I'm thinking about trying the Axiom m22ti's, just based on the incredible reviews and value.
    I would love your thoughts. My pockets are not particularly deep, but I really value my music, and I want to get the best bang for the buck.
    Many thanks for your input!!
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Hi Luyen. Welcome to HTF!
    Your question is a little advanced for the Basics Section. So I am going to move your post to the Recievers fourm where more of the experts in amps/separates hang out.
    Good luck and enjoy your stay.
  3. Jongyoon Lee
    Jongyoon Lee Stunt Coordinator
    Dec 3, 2002
    125
    Do you have the Adcom GFP 750? If you do, you may have a very hard time finding anything under $5,000, not $2,000, that can match the performance of 750, whether it's 2 channel preamp, HT pre/pro, or a receiver. That beast is by far the best preamp I have ever heard. You might have to go into Lexicon / Levinson / Classe realm to build HT system with as good music performance, but that's going to be a little bit above your budget. [​IMG]
    If your preamp allows pass through, you can connect HT pre/pro as pass through, then you can use Adcom in the music mode, and HT pre/pro in the HT mode. That may be complicated, but probably the only way to protect the music performance while adding the HT capability. Then you can add a nice subwoofer and extra surround channels. After all, 90% of the HT experience comes from a good subwoofer and surrounds.
  4. Doug_
    Doug_ Stunt Coordinator
    Nov 7, 2005
    53
    luyen,
    I think it sounds lik your on the right track. I would take the Outlaw over the Rotel. I have heard the 1056 and the 970 (basically the 1070 minus the amps)and the 970 sounds better to me.
    I think the Internet brands are a great deal. They usually give you a 30 day trial, so you may be out the return shipping, but I have always been impressed with the quality of the units I have bought (SVS, Outlaw). If you really enjoy 2-channel music you may want to look at the Outlaw 990 instead of the 1070. I had the 990 and 970 in my home at the same time and the 990 has better performance than the 970. It does not have amplification as it is a pre/pro, but you would have two channels with your Adcom amp and could add speakers/amps as you went along.
  5. luyen
    luyen Auditioning
    Jan 14, 2006
    4
    Bob, thanks for moving this post. Wasn't sure where this best fit. Jongyoon, I'm playing a GFA-545 amp and a GTP-400 pre/tuner. Doug, thanks for the advice. You're the first to recommend Outlaw over Rotel, but this concurs with reviews I have read.
